hallo
weche zündkerzen für willys 3a mit hurrikan motor,
mgf frank
zündkerzen
zündkerzen
AN 7 ist ausser Verkehr...sie heisst nun AutoLite 298 oder Du nimmst Champion J8C.
Es gibt auch Umschlüsselungen auf BOSCH... aber nimm nur eine der obigen.
Wie hast Du den F-Motor (vom 3b und 5 E) in den Motorraum reingebracht?
zündkerzen
Tiefer gelegt?
zündkerzen
Maintenance Part Numbers for Hurricane engines:
Rotor cap: Prestolite IAT 1041
Ignition points: Standard AL 4556P or #AL4556XP (the difference between P and XP is the quality.)
Points: NAPA CS725A or CS709
Condenser: NAPA AL 869 or AL 868 (with wire or with copper strap)
Cap: NAPA AL70
Rotor: NAPA AL69
Fan belt: Dayco 22425.
Oil Filter: Fram C-3P. Wix 51010 or NAPA 1010 or 1006 (1011 is same filter with 2 different size gaskets.) 1980's Mercedes-Benz diesels used the same filter.
Sparkplugs: Autolite A7, AC Delco 45 or Champion J-8. Note: Current Autolite replacement number is 295. A current Champion 841 (J8C) is suitable. AC has discontinued the 45 plug but hardware stores in small towns may still have stock from the 70's. Modern resistor-type plugs don't perform well on older engines.
6-volt Battery: Auto-Lite 1M-100, 100 AmpHour H 8 5/8" x W 7" x L 8 23/32"
12-volt Battery: Auto-Lite 11-HS, 50 AmpHour H 9 7/32" x W 6 25/32" x L 10 15/64"
Specifications
Spark plug gap: 0.030 in. (0.762 mm)
Spark plug torque: 25-33 lbs. ft. (34-44 Nm)
Cap: NAPA AL70
Rotor: NAPA AL69
Specifications
